PWM
Hello all,
I am new to microcontroller and to this forum.It seems I have a conceptional problem in PWM generation.
My Idea is:PWM module gemnarates a square wave which has the peak value 5 volt and low value 0 volt.I can set pulse period (and hence frequency) and pulse width using PPx and PWx registers respectively.The average voltage output which I get out of it is:5xduty cycle ratio.
If I change pulse width, I change duty cycle ratio.
Now,can I treat this output as an analog voltage?Can I run a device which needs analog voltage with this PWM output (even if I do not filter it)?
Could you please clear my confusions up?
(I am sorry for my elementary questions)
Regards,
Denis
  • "Can I run a device which needs analog voltage with this PWM output (even if I do not filter it)?"
    That depends on the device!
    Often, you don't need a specific filter circuit because the device itself provides an inherent filtering action; eg, a motor has a significant mechanical inertia, and this is often sufficient to provide the "filtering" effect for PWM drive.
