I am using the app note "AN029" and following the steps in the c8051f33x.pdf document regarding erasing the flash at 0x1a00. The lock byte has 0xFF in it. I am using the latest Cygnal drivers and the latest release of uVison2 (Keil). All conditions are met but the bank is not set to 0xFF? unsigned char xdata * pwrite; // pointer to FLASH used for writes //unsigned char xdata * idata pwrite; // pointer to FLASH used for writes // NOTE: this pointer must be located // in <data> or <idata> space! unsigned char *pread; // pointer to RAM used for reads //unsigned char code *preadCode; // pointer to FLASH used for reads char EA_save; // saves the current state of the ushort idata mySize; uchar idata myCheckSum = 0; PCA0MD &= 0xBF; // disable the watchdog: WDTE //pwrite = (unsigned char xdata *) 0x1DFF; //*pwrite = 0xFF; // interrupt enable bit. // disable watchdog timer //WDTCN = 0xde; //WDTCN = 0xad; ////////////////////////////////////////////////////////////// // PART A -- erase the FLASH page at SYSTEM_PARAMETERS address // initialize write/erase pointer pwrite = (unsigned char xdata *) SYSTEM_PARAMETERS; EA_save = EA; // save interrupt status EA = 0; // 1) disable interrupts (precautionary) PSCTL |= 0x02; // 2) Set the PSEE bit (register PSCTL). PSCTL |= 0x01; // 3) Set the PSWE bit (register PSCTL). FLKEY = 0xA5; // 4) Write the first key code to FLKEY: 0xA5. FLKEY = 0xF1; // 5) Write the second key code to FLKEY: 0xF1. PET_THE_DOG; *pwrite = 0xF5; // 6) Step 6. Using the MOVX instruction, write a data byte to any // location within the 512-byte page to be erased PET_THE_DOG; PSCTL = 0; // 7) Clear the PSWE and PSEE bits. // user software EA = EA_save; // re-enable interrupts
