Timer 3 data register
I do not understand T3 data register.I went through the data sheet.I understood al other registers.
Say, for example:
T3=0x5D00, then what does it mean? Does it mean that every such time interval the timer will tick?
Thanks in advance.
Denis
  • Hi Denis,
    The mode of operation of timer 3 is controlled by T3CON. Timer 3 can also work in conjunction with timer 2 or timer 4. In timer mode (which, I think, you are interested in,) T3 is a timer register, which means that it is incremented or decremented with every timer tick. If you intend to set the period of the timer, you will probably want to read about auxiliary timers' 2 and 4 reload mode.
    It's not really very straightforward, but that's the price of flexibility. I think most people familiar with C16x will agree that Infineon's documentation is very good. Read on, you will find all the answers there.
    Regards,
    - mike
  • Hi Mike,
    Thanks for your reply.Please just tell me one thing-if I want to use timer T3 only, then should I need to read about auxiliary timers' 2 and 4 reload mode?
    With best regards,
    Denis
  • Yes and no. Yes, because timer 3 can do a lot by itself. No, because timers 2 and 4 extend the functionality of timer 3 and you can find its basic functionality insufficient. So it depends on what you need.
    It would probably take you less time to read the manual than to post to this forum and wait for an answer.
    Regards,
    - mike
  • Hello Mike,
    Thanks for your reply.I once again went through the data sheet.Still I could not understand how to load T3 data register.Probably, I need only T3, not T2 and T4.I am a Mechanical background person, so I do not understand a lot of basic terms.So, would you please help me out?
    Thanks,
    Denis
  • Hi Denis,
    I guess I could. I'm not quite sure what exactly you are trying to do. Maybe just to set up a timer to generate periodic interrupts? Besides, maybe you are reading the wrong manual? The datasheet for a microcontroller doesn't provide detailed information about on-chip peripherals and their registers. The manual does. You could use the C167CS manual (it's big, 5.4 M bytes):
    http://www.infineon.com/cmc_upload/0/000/012/805/c167cs_um_v2.0_2000_07.pdf
    It's section 10.1.1 'GPT1 Core Timer T3'.
    Here is an example of configuration of timer 3:
    T3CON = 0x0040
    Basically all bits set to '0' except the 'run' bit. The timer will count up generating an interrupt each time it overflows, which would be once in every 21 ms (assuming 25 MHz CPU clock.)
    You can easily multiply this period by 2, 4, 8, ..., 128 by modifying the 3 least significant bits of T3CON (see formula & table in the manual.) If you need finer control of the period, you will have to use the reload feature of the timer which involves either timer 2 or timer 4.
    I hope this makes things clearer.
    Regards,
    - mike
