LPC932 Watch Dog Timer
Hi, I want to use the watch dog timer in the lpc932 and I think I have to specify that, by selecting that option in the "Device Configuration" box, contained in the ISP drop down menu from Flash Magic. Is that right? Well if it is, why the micro controller does not get programmed every time I make this selection?
Instead, it gives the message "unable to connect at the specified baut rate..."
I am doing the right thing to use the WDT?
  • ""unable to connect at the specified baut rate..."
    Sounds like the problem lies in your connection to your target, rather than any specific chip config settings in the PC options?
    Are you using a Dev Board?
    I wasted ages faffing around with my Keil Dev Board, because the CD shipped in the kit was the wrong revision for the board! :-(
  • Andy Neil, now that you mention it, I have a new evaluation board, but I am still using the software provided with the EMP900 Emulator board. Maybe that is where the problem is. I'll check!
