Does anyone know how to test that the "DEBUG" compiler option (active when "Debug Information" is checked on the Target Options Output tab) is enabled? I would like a simple test such as
#ifdef DEBUG
"how to test that the 'DEBUG' compiler option ... is enabled?." See my "digression" (Posted 10/31/02 8:01:43) in this thread: http://www.keil.com/forum/docs/thread1940.asp - This is another one to add to the list!
Could you turn the problem around? Instead of enabling the compiler debug info in the uVision options, you define (or not) a preprocessor symbol, and then use that in your source files to determine whether or not to enable debug features; eg,
#ifdef DEBUG_MODE #pragma db //Debug mode - TRACE causes printf output #include <stdio.h> #define TRACE(params) printf params; #else //Release mode - TRACE expands to nothing! #define TRACE(params) #endif
This is exactly what I meant and need. I have numerous #ifdef's in the code allowing it to be built for multiple flavors of the same machine. Based on an ID being defined, I place an identifying letter on the end of a part number string to show all the options it was compiled with while it is in development. This allows a double check to make sure a piece of code being tested is designed for the machine in question. When "Debug Information" is selected, is there anything that I can do an #ifdef on to determine that the debug code is compiled in (source file names, line numbers, etc)?
I have found so many things I need done that uVision can not do (file replacement/renaming - debug mode - many builds from same group of files) so I have reverted to commandline operation. I do this by regular .bat files and if if you want to know how, let me know. Erik
