The definition 'Parameter_Table' has a starange behavior in my code. Is there an error in this code or a bug in C51? In cases 0x20 and 0x21 this code returns quite different (wrong) values compared to cases 0x10 and 0x11 ( or 0x30 and 0x31 ) respectively. Instead of Parameter_Table(PARAMETER_NUMBER-x) it returns something like 'Parameter_Table(-x)+PARAMETER_NUMBER';
#define PARAMETER_SIZE 13 #define PARAMETER_NUMBER 8 union parameter_type { struct { unsigned char start_1; unsigned char params_1[PARAMETER_SIZE]; unsigned int check_1; } parst; unsigned char table[PARAMETER_NUMBER][PARAMETER_SIZE+3]; }; #define Parameter_Start (0x1000) #define Parameter_Table(n) (Parameter_Start+n*(PARAMETER_SIZE+3)) #define Parameter_Check (Parameter_Start+sizeof(union parameter_type)) unsigned int test_defines (unsigned char tmp) { // unsigned int tmpw; switch (tmp) { case 0: tmpw = Parameter_Start; break; case 0x10: tmpw = Parameter_Table(0); break; case 0x11: tmpw = Parameter_Table(1); break; case 0x20: tmpw = Parameter_Table(PARAMETER_NUMBER-8); break; case 0x21: tmpw = Parameter_Table(PARAMETER_NUMBER-7); break; case 0x27: tmpw = Parameter_Table(PARAMETER_NUMBER-1); break; case 0x30: tmp = PARAMETER_NUMBER-8; tmpw = Parameter_Table(tmp); break; case 0x31: tmp = PARAMETER_NUMBER-7; tmpw = Parameter_Table(tmp); break; } return tmpw; }
37: case 0x10: 38: tmpw = Parameter_Table(0); C:0x0DD2 7C10 MOV R4,#koe(0x10) C:0x0DD4 7D00 MOV R5,#B?SMEM(0x00) 39: break; C:0x0DD6 8024 SJMP C:0DFC 40: case 0x11: 41: tmpw = Parameter_Table(1); C:0x0DD8 7410 MOV A,#koe(0x10) C:0x0DDA FC MOV R4,A C:0x0DDB FD MOV R5,A 42: break; C:0x0DDC 801E SJMP C:0DFC 43: case 0x20: 44: tmpw = Parameter_Table(PARAMETER_NUMBER-8); C:0x0DDE 7C0F MOV R4,#0x0F C:0x0DE0 7D88 MOV R5,#TCON(0x88) 45: break; C:0x0DE2 8018 SJMP C:0DFC 46: case 0x21: 47: tmpw = Parameter_Table(PARAMETER_NUMBER-7); C:0x0DE4 7C0F MOV R4,#0x0F C:0x0DE6 7D98 MOV R5,#SCON0(0x98) 48: break; C:0x0DE8 8012 SJMP C:0DFC 49: case 0x27: 50: tmpw = Parameter_Table(PARAMETER_NUMBER-1); C:0x0DEA 7C0F MOV R4,#0x0F C:0x0DEC 7D98 MOV R5,#SCON0(0xF8) 51: break; C:0x0DEE 8012 SJMP C:0DFC
Take a look at the preprocessor output file - I'd guess you might have problems with the macro expansions, possibly due to insufficient parentheses. Stefan
#define Parameter_Table(n) Parameter_Start+n*(PARAMETER_SIZE+3))
#define Parameter_Table(n) (Parameter_Start+(n)*(PARAMETER_SIZE+3))
There's no need for the macros at all; they're getting in the way and causing bugs. Let the compiler handle it.
#define ConfigBaseAddress 0x1000 typedef ParamCheckType ???; // not mentioned in original code posted typedef struct { U8 start; U8 value[PARAMETER_SIZE]; U16 check; } Parameter; typedef struct { Parameter params[PARAMETER_NUMBER]; ParamCheckType check; } ParameterBlock; ParameterBlock config _at_ ConfigBaseAddress ;
Thank all of you for the help. Actually this is a slightly simplified part of a handler for serial EEPROM in an old project. That's why the parameters are in blocks. The more recent version of the project uses the memory class HDATA, the XBANKING.A51-like interface to an EEPROM-handler (C51).
