Hi, can me help anybody ? How can I affect location of program code in memory (e.g. Program SRAM, External memory, Flash,...)? I use uVision 3 and Keil MCB-XC167 Basic. Thx !
The typical configuration with MCB-XC167 BASIC is the on-chip program memory (this is also the most common configuration for the XC16x device family). You may start with the example in Keil\C166\Boards\Keil MCB-XC167\Blinky_OCDS.
you have to setup the User Classes in the L166-Locate section (target options).
ICODE (0x000000-0x007FFF), NCODE (0x000000-0x003FFF), ...
