pc-lint problem
I am using uVision2 version 2.37 and pc-lint version 8.00o.
I have included the co-kc51.lnt and env-keil.lnt in the setup, as well as the pertinent include file paths.
All I get is PC-Lint running and the header. I have checked to make sure that the env-keil.lnt contains the right info.
I'm at a loss.
If I try to run if from a batch file, it seems to run but can find the ansi standard header files and they are not in the Keil directory
Any ideas would be welcome
  • This is the project-specific lint file that I use:
    -ic:\lint\lnt
    // Keil C51
    co-kc51.lnt -si4 -sp4
    // Codewright editor
    env-cw6.lnt
    // include paths for project
    -ic:\Keil\C51\inc
    // four additional project -i here
    -e537			 // repeated include file
    -e655			 // bit-wise op uses compatible enums
    -esym(553,DEBUG) // undefined, assumed 0
    -esym(788,*Num*,*Force16*)  // enum constant not used in switch
    -e834			// operator '-' followed by op '-' is confusing
    The ANSI headers are in c:\keil\c51\inc on my machine, which I think is the standard installation. You'll still need to tell lint where to find them, though.
  • Thanks Drew,
    I just didn't go down far enough in the INC directory. That solved the execution problem.
    I can now run it from the DOS prompt. So I know PC-Lint is working.
    I cannot run it from Keil tools dropdown. It just puts the PC-Lint header but the results don't seem to pipe to the output window. I have the env-keil.lnt which is supposed to solve this.
    Frustrating!
  • I don't know that I can help you much here, since I usually run lint from my editor and not the Keil IDE.
    I did hop into uVision (v2.32) and tried it. I did "Setup PC-Lint", added the c:\lint\lnt directory in the top box, pointed it to the executable, and added my project lint file (above) as the "configuration file". So when I do "Lint all C Source Files", I get the same result. I see the PC-Lint banner in the Build window, and nothing else.
    So we presumably both are missing a configuration step.
  • My suspicion is that it's a piping issue.
    Something is wrong with the env-keil.lnt and it doesn't pipe to the Output window.
    It looks pretty intimidating but I guess I'll have to try to get into it.
    I appreciate your help and the independent verification that it doesn't work on someone else's Keil IDE makes me stop looking for my own errors and look into the configuration.
  • With the help of Keil, I got PC-Lint working from the tools menu.
    the command will not accept
    C:\LINT\LINT-NT.EXE
    only small caps allowed
    I had to remove all include files except
    c:\keil\c51\inc
    and I could use only 1 *.lnt file configurstion file. I had to combine them all into one.
    forget the env-keil.lnt. It's not needed
    So, duplicating your parameters which work in the batch mode won't work unless you do the above
  • Hmm...
    I use all caps in my PC-Lint setup and it works OK. I include:
    C:\Keil\C51\INC
    C:\Keil\C51\INC\Atmel
    I had the same problem as you reported originally. But I was using (someone else's) custom *.lnt that used +os to redirect the output from the Keil Build window into a file.
    Check out http://quest.phaedsys.org/ for tips on hitex/Keil/8051s.
