Hi, i want to put some assembly instruction in my c program, using .asm and .endasm but it seem doesn't work. Can anybody help, i'd appreciate your respond. sincerly, hardian hardian_97@yahoo.com
Did you use the SRC directive to when compiling?
"using .asm and .endasm" The correct usage is #pragma asm and #pragma endasm See the examples in the manual. "but it seem doesn't work." What do you mean by, "doesn't work." - precisely what did happen? What error/warning message(s) did you get?
There's an app. note here somewhere on this. Basically, Keil C51 can't do in-line assemlby like other hosted compilers. You need to compile your C/asm file using a compiler directive SRC to create an assembler file. Then you assemble that file into an object file. Look for the app. note on Keil's website, this issue has been talked about quite a lot.
"There's an app. note" And it's in the manual. Search the PDF file for "ENDASM" with uVision, you just need to check the 'Generate assembler SRC file' and 'Assemble SRC file' options
