C51: Bit arrays
I'm using an array of ints in the bit addressable memory area as a crude bit array
bdata unsigned int sample_window[SAMPLE_WINDOW_LENGTH];
//bit addressable array in bit memory
I'm using a mask to read from the array, however when I try to write a new bit in using the mask and a bitwise ex-or bits in more than one byte get changed.
sample_window[byte] = ((sample_window[byte]) ^ mask);
//change location by bit exor
any ideas on a better implementation?
