simulation of sbuf
SBUF is not a regular register: when you write to it you send a character on the serial line, and when you read it you empty the serial line buffer
Keil simulates sbuf like if it was a normal variable because if you try to do the same thing on hardware (emulator or chip) it won't work.
  • The simulator maintains two VTREG's for exactly this purpose.
    SIN is the input register
    SOUT is the output register
    More information about this is provided in the Getting Started with uVision2 User's Guide, Chapter 5, CPU Pin Registers (VTREGs).
