Animate program execution
I try to animate the program execution
based on the Q&A from tech support. But
I still not sure how I am going about
doing it. The explanation is very poor.
I don't know whether should I actually
insert the ANIMATE function at every
single on my source code? or there
is a way to enter the function on
DSCOPE window. COuld any body in this
forum shred some light into this topic?
Here is the post:
DSCOPE: IS THERE AN ANIMATE MODE?
QUESTION
How do I make dScope rapidly single-step through my program? I want an animate feature that makes dScope run in "DEMO" mode. This way, I can see the lines of code that are running.
ANSWER
The following dScope function does what you want. You may want to switch into MIXED mode when viewing the DEBUG window.
func void animate (char delay) {
while (1) {
int i;
exec("t");
for(i=25*delay; i!=0; i--);
When you want to animate program execution, enter the following in the command window:
animate (1)
The argument passed to the animate function determines how fast lines are executed. The smaller the number, the faster your program runs. A value of 0 provides no delay. A value of 10 steps through your program slowly. Try 5 as a starting point. If your PC is slow, you may want to change the step weight (25*delay) to something like 10*delay.
  • Note that the example is a dScope function: that's a function that you write in the debugger's command language, to be performed by the debugger - a sort of debugger "macro"
    It is not part of your application!
    I'm afraid I'm not familiar with dScope, as I use uVision - but uVision Debug Functions are well documented in the Getting Started with uVision manual.
    I suggest that you consult the dScop manual?
