Hello everyone, I am trying to program PID algorithm in c++ first.It is like this: output(i)=Kp*error(i)+Ki*delT*(summation from 1 to i)error(i)+Kd/delT*(e(i)-e(i-1)) This is what I wrote: #include<iostream> using namespace std; int main(){ float error,Paction,Daction,Iaction,lastError,delT; float Kp,Ki,Kd,setPoint; float measurement=0,output=0; int i; cout<<"Enter the value of Kp,Ki,Kd,delT:"; cin>>Kp>>Ki>>Kd>>delT; cout<<"Enter the Value of Set Point:"; cin>>setPoint; Iaction=0; lastError=0; for(i=0;i<4;i++){ error=setPoint-measurement; Paction=error*Kp; Iaction+=Ki*delT*error; Daction=Kd*(error-lastError)/delT; output=Paction+Iaction+Daction; lastError=error; measurement=output; } cout<<"Output:"<<output<<endl; return 0; } I am confused.Is it ok? Thanks
It seems okay to me. Only that is confusing is "dt" term . You need to describe the system .ie how the error signal changes with respect to time for accurate simulation results. Use eulers Integration formula then. Nitin
Hi, What is PID? Rgds Raj
more info here.... http://arri.uta.edu/acs/ee4314/lectures/RootLocus/pidLL.pdf
