My test routine is as follows.
#pragma OPTIMIZE(0) #pragma FLOATFUZZY(3) #include <intrins.h> void main() { float f1; float f2; unsigned long l1; unsigned long l2; f1 = 0.9; f2 = f1 - 0.1; // f2 = 0.8 f1 = 0.8; // f1 = 0.8 // Show the binary representations of the floats. l1 = *(unsigned long *)&f1; // 0x3F4CCCCD l2 = *(unsigned long *)&f2; // 0x3F4CCCCC if(f1 == f2) { // not equal _nop_(); } while(1); }
Does the program start to work with floatfuzzy(4) or higher? What values do the floats take on after they are rounded? (Trace into the floating point routine in the debugger.) One possible bug might be in exactly what Keil means when they say the low "three" bits are "rounded". Depending on your interpretation of that phrase, that might mean a number of things. Does the library code add 4 and truncate? Add 3 and truncate? Add 7 and truncate?
"One possible bug might be in exactly what Keil means when they say the low "three" bits are "rounded". Depending on your interpretation of that phrase, that might mean a number of things. Does the library code add 4 and truncate? Add 3 and truncate? Add 7 and truncate?" Indeed, I've always wondered what they do. Whatever it is, though, it is still a really bad idea to test floats for (in)equality. You're likely to wind up with code that works until some unfortunate combination of values causes it to fail. You're probably lucky that you've started off with a failure condition. Stefan
