Using the C51 Ver 7.07, if the directive NOAMAKE is specifiy in the command line, I get an error from the compiler that state "unknown control"; BUT if I specify NOAM (abbreviation of the directive) it works fine... Any comments ?
The directive name 'NOAMAKE' was brocken in the directive table. It will get fixed in the next release. For the moment use 'NOAM' (as you have already figured out).
Thanks for the update, Regards, D. Uhlmann
