Dear all, I just started to use Keil Software (a beginner). I have tried to run measure.uv2 and it works. However, I tried to build my own by just create a new project, then copy all the .c & .h file to it. I try to run it but I fail. I noticed that it is because I didn't copy the .dmo file. May I know: 1) how do I create a .dmo file 2) what is the usage of it? 3) When should I use it? Thanks a lot
I have never had to use a .DMO file! What errors do you get? Try following the steps in the uVision Getting Started Guide
The following knowledgebase article lists the file types that uVision2 uses/creates. http://www.keil.com/support/docs/1774.htm Jon
DMO is not on that list! The latest C51 download includes DMO files in the following example projects:
DES Dhry Sample517 Measure Traffic Whets
See http://www.keil.com/forum/docs/thread3667.asp Jon
