Hiya guys thought i would start a new thread, and ask about help on setting up and using extra external interrupts. all help much appreciated
What is extra external interrupts? Are you refering being able to activate standard, but unused in the current design, interrupts without external stimulus? If you are, then it certainly is possible. The serial port RI/TI flags are really easy since they don't externally connect to anything. INT0/INT1 are equally easy if the pins are disconnected on the processor. If you are trying to extend the interrupt capability then more information is needed. What are you asking?
"thought i would start a new thread, and ask about help on setting up and using extra external interrupts." Go on then - ask a question!
ok, i will :o) I would like to know how to setup and use the INT2 on a 80592. it looks as if u can use it for CTI0 and INT2. i can enable the interrupt, but i cant ssem to get access tot he interrupt via P1.2, as suggested in the simulator. I can activate the interrupt via the interrupt box in the simulator. but i need the pins to work.
Ok, i have a better understanding now, and i require help understanding how to set up Timer2 Capture control
