Hi every body I don't know why I don't have the float part of the temp var.
float temp; int H_Value; int L_Value; int value = 55; temp = value / 10; H_Value = (int)temp; L_Value = (int)(temp - H_value)*10;
The program behaves exactly right --- it's your expectation that's incorrect here. The bug in your program is that there's not a single manifest floating point number in it.
Or, to be more precise: temp = value / 10; is an integer (value) divided by an integer literal ("10"), which results in a integer (5). That integer is then assigned to temp, and converted to a float representation (5.0) in the process. You want to do the division in floating point. So, try something like: temp = (float)value / 10; or temp = value / 10.0; to have the expression on the right hand side evaluate as a float. It occurs to me that you actually want the division to truncate for H_value. You could leave out "temp" entirely: H_value = value / 10; L_value = (value % 10) * 10; This code has no floating point at all, which will do nice things for speed and space requirements. (I'm not entirely sure you really want that last "* 10". If you're trying to separate the number into multiples of ten, and the leftover part, then it should just be L_value = value % 10, and your original code should have been L_value = temp - H_value * 10; ) Hmmm: Jon asked a few weeks back how often people actually needed both quotient and remainder from a single divison. Here's yet another case.
And note that this is all standard 'C' - nothing specifically to do with Keil. Therefore, in this case, reading the Keil Manual will not help you - because the Keil manual assumes that you already know ANSI 'C', so only goes into the implementation-specific details. You will need to refer to K&R, or another good 'C' textbook.
Thank you very much Kobi
