problem with CS signals
Hello.
I'm trying to use simulated serial port with MCB167-NET. I've burned the monitor program in FLASH (two devices, one for even and the other for odd). For the simulated serial I've chosen P8.4 and P8.5 pins of the CS167-LM device. I've changed the config.ini file of the monitor program I've burned in the FLASH.
I put the switch number 4 (BSL) off. But I cannot download my program to the RAM, it finds a transmission error.
With a logic analizer, I can see the CS0 (for the ROM) is oscilling, and the CS1 (for the RAM is off all the time.
What I'm doing wrong? Should I change some of the configuration jumpers?
I've tried to put EA off, but then the CS0 is always ON.
Can anybody help me? Thank you
  • Hi Beatriz,
    Did you also change the INST167.A66 file to use the new port pins? I would also suggest that you CAREFULLY review EACH setting in the CONFIG.INC file to see if it can prevent the monitor from working. I remember it took me a few iterations to get the monitor in ROM working.
    - mike
