Can anyone point me in the direction of any information/code on programming on-chip Flash. I have application note 1496 but require more information than it offers.
When I run the following code instead of getting the flash status register on polling I am reading the value from the flash at the address I am trying to program. Has anybody else come accross this problem ?
uint16_t ProgramWord( uint16_t segment, uint16_t segment_offset, uint16_t data ) { uint16_t rc = 255 ; __asm{ BCLR IEN NOP NOP PUSH R5 PUSH R6 PUSH R7 MOV R5,#01554h ;load auxilary register R5 with command address ;(used in command cycle 1) MOV R6,#02AA8h ;load auxilary register R6 with command address ;(used in command cycle 2) SCXT DPP0,#08h ;push data page pointer 0 and load it to point ;to segment 1 MOV R7,#0A8h ;load register R7 with 1st CI enable command MOV [R5],R7 ;command cycle 1 MOV R7,#054h ;load register R7 with 2nd CI enable command MOV [R6],R7 ;command cycle 2 MOV R7,#0A0h ;load register R7 with Program Word command MOV [R6],R7 ;command cycle 3 POP DPP0 ;restore DPP0: following addressing to the Flash ;will use EXTended instructions ;R8 contains the segment to be programmed ;R9 contains the segment offset address to be programmed ;R10 contains the data to be programmed MOV R8,#02h ;segment MOV R9,#0000h ;segment_offset MOV R10,#0000h ;data EXTS R8,#1 ;use EXTended addressing for next MOV instruction MOV [R9],R10 ;command cycle 4: the E/P.C starts the execution of ;Programming Command ; Data-Polling after word programming : Data_Polling : EXTS R8,#1 ;use EXTended addressing for next MOV instruction MOV R7,[R9] ;read Flash Status register (FSB) in R7 MOV debug12,R7 MOV R6,R7 ;save it in R6 register XOR R7,R10 ;Check if FSB.7 = Data.7 (i.e. R7.7 = R10.7) JNB R7.7,Prog_OK ;Check if FSB.5 = 1 (Programming Error) JNB R6.5,Data_Polling EXTS R8,#1 ;use EXTended addressing for next MOV instruction MOV R7,[R9] ;read Flash Status register (FSB) in R7 XOR R7,R10 ;Check if FSB.7 = Data.7 (i.e. R7.7 = R10.7) JNB R7.7,Prog_OK ;Programming failed: Flash remains in Write Operation. ;To go back to normal Read operations, a Read/Reset ;command must be performed Prog_Error : MOV R7, #0F0h ;load register R7 with Read/Reset command EXTS R8,#1 ;use EXTended addressing for next MOV instruction MOV [R9],R7 MOV rc,#00h Prog_OK : POP R5 POP R6 POP R7 BSET IEN NOP NOP } return rc ; }
Does the flash actually get programmed with your value? I suspect not. Command cycle 3 should probably go to the 5555H address (R5) instead of 0AAAAH (R6). If the flash never enters programming mode, it will just read back normally instead of going into the data polling state.
Sorry should have spotted that myself. Thanks.
