Using Built in Baud rate generator on 89C669
Does anyone have any sample code that shows how to set up uart 0 to use the internal Baud rate generator ?
  • Dear Andy,
    I am also facing the same problem with 89C669. Do you have any solution for this? Please help me.
    Thanks in advance.
    Suhas
  • My Code for Using Built in baud generator for both serial ports. Hope it helps :-
    // initialise on board comms
    BRGCON = 0;
    //12 MHz
    BRGR0 = 0xD2;
    BRGR1 = 0x4; //Set To Baud rate generator to 9600
    //11.0592 MHz
    // BRGR0 = 0x7E;
    // BRGR1 = 0x4; //Set To Baud rate generator to 9600
    BRGCON = 3;
    T2CON = 0x30; // RCLK=1. TCLK = 1, Timer 2 Disabled
    SCON = 0x50; // SCON: mode 1, 8-bit UART, enable rcvr
    REN_0 = 1;
    ES0 = 1; // Enable Interrupt
    TI_0 = 1; // TI: set TI to send first char of UART
    //Uart 2
    S1CON = 0x50; // SCON: mode 1, 8-bit UART, enable rcvr
    REN_1 = 1;
    ES1 = 1;
    TI_1 = 1; // TI: set TI to send first char of UART
  • Hi
    #define Kristall        19660800
    #define Baud            19200
    #define	BRATE		(Kristall/Baud)-16
    void    StartRS232(void)
    BRGR0 = BRATE & 0x00ff;
    BRGR1 = (BRATE & 0xff00) / 256;
    SM0_0 = 0;
    SM1_0 = 1;
    SM0_1 = 0;
    SM1_1 = 1;
    RCLK = 1;
    TCLK = 1;
    BRGCON = 0x03;
    REN_0 = 1;
    REN_1 = 1;
    TI_0 = 1;
    TI_1 = 1;
