I have a MCB167-NET board, and have a problem when I try to download the program using "Monitor 166 in ROM". I have this message: "The file *.mon or *.bot could not be found in the monitor directory of your installation. Please reconfigure monitor again or copy the preconfigured mon or bot files from the hardware manufacturer into the "monitor" directory." I have burned a FLASH with the monitor program because I want to use simulated serial port. Can anyone help me? Thank you
Have you selected 'Monitor166 in ROM' in your Target Options->Debug->Monitor Settings ? - mike
Yes, I've done it. I'm thinking maybe I have to change some of the switches of the board.
