Hlello,everyone, Now I use the C167 system, and when I have compiled a project with uVision, I will find the first line in the HEX file like this:":020000020000FC". In the "Intel HEX File Format" section of "C16x/ST10 Assembler and Utilities User's Guide ", it says that "The Intel HEX file contains 8086 segment address records to specify a paragraph number (one paragraph is 16 bytes).The paragraph number is used as the offset for all subsequent data records in the HEX file.". And I know that "0000" befor the "FC" is the paragraph number,but I don't understand what's the true meaning of the "paragraph number". And why a paragraph is 16 bytes? can you tell me ? Thanks .
This historically comes from INTEL and is not relevant for you, since the segments in the C16x and XC16x are fixed. At a PC you find following register Codesegment CS IP Instructionpointer Datasegment DS SI/DI/BX (Index register ) Extrasegment ES SI/DI/BX Stack-Segment SS SP/BP ------------------------------------- IP = Instruction Pointer SI = Source Index DI = Destination Index SP = Stackpointer BP = Base Pointer ------------------------------------- Segmentregisters are only 16 Bit wide, what is not enough to address e.g 1 MB memory or more. That's why it the tricky offset addressing, was found. We divide the memory by 16. This results in 65536 points in memory which have a distance of 16 byte to each other. This points are called PARAGRAPH's. if we now need a 20-bit address to address such a paragraph, we must multiply the contence of the related segment register by 16. With Hexa-numbers this is easy done. Simply concatenate a '0'. This 20-bit addresse is now the start point of the segment. To move in such a segment you need a second register called offset register. .... So we have a notation as Segment : Offset e.g. C000:0400 PC-side e.g. C014BEH CO = segment 14BE = offset Offsetregisters are 16-bit wide too and so they can only address 64 KByte. This is the reason, why a segment can be max. 64kByte. But as you see, here we use data page pointer as offset with 16KByte each. So the calculation of addresses is slightly different between and micro.
Thanks. Then it is not use for me in the C167 system?I want to make sure. If some use, then how can I change the paragraph number?
Usually you can select the output format. This is than HEX-386(H167) under 'Options for Target" --> "Output". So you get a Extended Linear-Address Record. There is no reason to think about the paragraphs. µVision2 will handle it for you.
