I want to run a batch to do something to my hex file after a build, so I specify that batch file as "User Program #1" in the project settings. But I don't want to give it an absolute path, because it should be portable and work no matter what my working directory is. However, if I just type the name of the batch file I get an error saying it can't execute that .bat file. Is there some way to make uVision execute files in the same directory that the project is in without specifying an absolute path? Thanks!
Have you added the path to that file to the PATH environment variable? Jon
Have you tried:
.\file.bat
I don't want to add the path to the PATH env. variable. I want to be able to put my project and files into whatever directory I choose and have a successful build. I also did try the ".\file.bat" but it still complains that it can't execute that file.
Are you sure it's in the same folder as the uVision Project (.uv2) file? Have you tried the Key Sequences? Can you post the full text of the message you receive?
ah, I figured it out. Previously, I had an absolute path to the batch file. When I originally specified the file, uVision put "" marks around the whole path. Then when I changed it to just the batch file name (no path) I deleted the first " but neglected to delete the second " ... as soon as I deleted the second " it all worked fine. Thanks for the suggestions ;-)
