SVCS and Microsoft Source Safe. Configuration: ********************************************* Template file-->C:\Keil\UV2\Microsoft Visual SourceSafe.SVCS user-->user1 Database-->C:\VisualSourceSafe\BaseVSS2\srcsafe.ini for the item Put Current Version: Command-->C:\Program Files\Microsoft Visual Studio\Common\VSS\win32\Ss.exe Arguments-->CheckIn "%F" -C@"%Q" -I- -K Environment-->SSDIR=%V; SSUSER=%U ********************************************* With this configuration, only SourceSafe Explorer work. Others items of SVCS don't work. Anybody can help me ? thanks in advance.
Actually there is a difference between various SourceSafe Versions. These differences are taken care of in the actual uVision3 version. uVision3 provides therefore two different SVCS files for the Microsoft Visual SourceSafe. In case that you are using uVision2 you may have problems using SourceSafe (basically on Version 5 is working).
