Hi all , I would like to know the method of transmitting 16bit binary data (from 8255 port A & B) and floating point ouput result using serial comm(rs232) from 8051 to pc. i know we can use printf method. But if i want to use SBUF method, should i convert the binary data or the floating point calculated result using sprintf method and transmit the buf (from sprintf) to SBUF. your help is much appreciated. thanks
Depends on what the receiver expects. Do you need to convert the numbers to human-readable ASCII (via sprintf), or does it suffice simply to send the bytes themselves? Avoiding the conversion to ASCII will be faster and probably result in fewer bytes sent. Converting to ASCII will be easier to debug, since you can plug in any ordinary terminal program and see what comes out.
"i know we can use printf method. But if i want to use SBUF method..." Just to be clear, the printf() method does use the SBUF method, as ends up calling putchar(), which outputs characters using SBUF. "...should i convert the binary data or the floating point calculated result using sprintf method and transmit the buf (from sprintf) to SBUF." Sure you can do that, but it ends up not being a whole lot different than printf() from the standpoint of binary-to-ASCII conversion. However, it does allow you the flexibility to tailor your output methods (e.g., interrupt-driven output if you want). But back to the post's title "How to transmit binary...", if you are trying to avoid all the overhead of binary-to-ASCII conversions (including floating point conversions), you can transmit the data just as it "appears" in memory. You just need to frame the data so that the receiving end know where the binary data begins and ends and what type of data is contained in the frame (so it can distinguish, for example, a 16-bit integer from a 32-bit floating point number). There are a couple of documents (hdlcbcc.pdf and tinyrpc.pdf) on http://dhenry.home.sprynet.com that describe a simple binary framing protocol (HDLC BCC 15.1) and a tiny RPC-like call/reply protocol that might give you some ideas if you are truly trying to do binary comms.
"Avoiding the conversion to ASCII will be faster and probably result in fewer bytes sent" However, not all serial links will pass data transparently: make sure that you disable software flow-control, and any special handling of CR, LF, FF, etc, etc,...
"However, it does allow you the flexibility to tailor your output methods (e.g., interrupt-driven output if you want)." You can still do this just as easily with printf - see the "Interrupt-Driven Serial I/O Support for printf" example project in the Downloads area on this very site: http://www.keil.com/download/docs/intsio.zip.asp
