Hi all, I have done one simple serial rs232 c program in keil and when download in eprom it produce no output on the termulator.This program is to do serial transmission from 8051 to pc. Here is the code:
/* RS232 SIMPLE TRIAL */ #include <stdio.h> #include <reg51.h> /*Function to initialize RS232 serial port*/ void serial_init() { SCON=0X50; //Setup for 8-bit data TMOD=0X20; //Setup Timer 1 for auto-reload TH1=0XFD; //Setup for 9600 baud TR1=1; //Turn on Timer 1 T1=1; //Indicate Ready to Transmit } /*This func display a null-terminated string on the rs232 port*/ void send_serial(unsigned char*s) { while(*s!=0x0) { SBUF=*s; while(!T1) { } T1=0; s++; } } /*Start of main program*/ main() { unsigned char crlf[]={0x0D,0x0A,0x0}; serial_init(); for (;;) { send_serial("Another test"); send_serial(crlf); } }
You might want to try using Transmitter Interrupt (TI) not T1.
http://www.keil.com/download/docs/intsio.zip.asp
Hi Bob, Thank-you very much for noticing the typo error mistake. After changing it to TI it works fine. thanks.
