Problems with At 89c2051when writing data to eeprom(24c256)
The atmel recives data ,if data corect it saves it into an eeprom (fm24c256)the only problem i have is that when write is performed it adds at the end of the data string to be saved some trash. If there is someone willing to help plz mail me: geosan1638@yahoo.com
  • Hi,
    Please post your code so that we can have a look at it...
    Rgds
    Raj Shetgar
    $mod51
    wena equ p3.3
    sda equ p3.5
    scl equ p3.4
    DSEG AT 0020H
    ORG 0020H ; stack origin
    stack: DS 0020H ; stack depth
    scan1: ds 1 ;hold 1. scan
    oldkey: ds 1 ;hold old key
    CSEG
    ORG 0000H ; power on/reset vector
    jmp on_reset
    ORG 0003H ; external interrupt 0 vector
    reti
    ORG 000BH ; timer 0 overflow vector
    reti ; undefined
    ORG 0013H ; external interrupt 1 vector
    reti
    ORG 001BH ; timer 1 overflow vector
    reti ; undefined
    ORG 0023H ; serial I/O interrupt vector
    reti ; undefined
    ORG 0040H ; begin constant data space
    ;----------------------------------------PROGRAM START ---------------
    ORG 00E0H ; begin code space
    USING 0 ; register bank zero
    on_reset: lcall init
    START: clr p3.2
    mov a,#'t'
    lcall putc
    MOV R1,#040h
    MOV R5,0
    sr0: lcall serin
    lcall putc
    mov @R1,a
    INC R1
    inc r5
    cjne a,#'Y',sr1
    ljmp start
    sr1: cjne a,#'N',sr2
    ljmp start
    sr2: cjne a,#'.',sr3
    ljmp sr5
    sr3: mov a,r5
    cjne a,#040h,sr0
    ljmp start ;buffer overload
    sr5: LCALL SERIN
    CJNE A,#'L',SR6
    LJMP START
    SR6: CJNE A,#'.',START
    ljmp savedate
    savedate: clr p3.2
    mov @r1,a
    inc r1
    mov dptr,#0000h
    sv0: lcall rdi2c
    cjne a,#0aah,sN1
    LCALL ADD40
    ljmp SV0 ;not empty
    sn1: mov r0,#0aah
    lcall wri2c
    inc dptr
    ;savebufer
    MOV R1,#040H
    mov r4,#03fh
    ssev: MOV a,@R1
    lCALL PUTC
    mov r0,a
    LCALL wri2c
    inc dptr
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    INC R1
    DJNZ R4,ssev
    ljmp start
    MOV A,DPH
    CJNE A,#0FFH,sv0
    MOV A,DPL
    CJNE A,#0FFH,sv0
    loop: ljmp loop ;full eep loop infinit
  • PUTC: JNB TI,$
    CLR TI
    MOV SBUF,A
    RET
    SERIN: JNB RI,$
    CLR RI
    MOV A,SBUF
    RET
    INIT: setb p3.2
    CLR TR1
    MOV SCON,#05ah
    MOV Tmod,#020h
    mov TH1,#0E8h
    mov tl1,th1
    SETB TR1
    MOV A,#0E9h
    DJNZ ACC,$
    jb p3.7,notera
    ljmp erase_eep
    mov r1,#040h
    mov r7,#64
    sterram: mov a,0
    mov @r1,a
    inc r1
    djnz r7,sterram
    notera: ljmp START
    erase_eep:
    mov dptr,#0000h
    era1: mov r0,#0ffh
    lcall wri2c
    nop
    nop
    nop
    nop
    inc dptr
    MOV A,DPH
    CJNE A,#080H,era1
    MOV A,DPL
    CJNE A,#000H,era1
    clr p3.2
    ljmp start ;rec overun
    wri2c: clr wena
    MOV A,#0a0h
    LCALL OUTS1
    MOV A,dph
    LCALL OUT1
    MOV A,dpl
    LCALL OUT1
    MOV A,R0
    LCALL OUT1
    LCALL STOP1
    setb wena
    RET
    Rdi2c: MOV A,#0a0h
    LCALL OUTS1
    MOV A,DPH
    LCALL OUT1
    MOV A,DPL
    LCALL OUT1
    MOV A,#0a1h
    LCALL CREAD1
    RET
    CREAD1: LCALL OUTS1
    LCALL IN1
    LCALL STOP1
    RET
    OUTS1: MOV R2,#8
    SETB SDA
    SETB SCL
    NOP
    NOP
    NOP
    nop
    CLR SDA
    NOP
    NOP
    NOP
    nop
    CLR SCL
    OTSLP1: RLC A
    JNC BITSL1
    SETB SDA
    LJMP OTSL11
    BITSL1: CLR SDA
    OTSL11: SETB SCL
    NOP
    NOP
    NOP
    nop
    CLR SCL
    DJNZ R2,OTSLP1
    SETB SDA
    NOP
    nop
    SETB SCL
    NOP
    NOP
    NOP
    nop
    CLR SCL
    RET
    OUT1: MOV R2,#8
    OTLP1: RLC A
    JNC BITL1
    SETB SDA
    LJMP OTL11
    BITL1: CLR SDA
    OTL11: SETB SCL
    NOP
    NOP
    NOP
    nop
    CLR SCL
    DJNZ R2,OTLP1
    SETB SDA
    NOP
    nop
    SETB SCL
    NOP
    NOP
    NOP
    nop
    CLR SCL
    RET
    IN1: MOV R2,#8
    SETB SDA
    INLP1: CLR SCL
    NOP
    NOP
    NOP
    nop
    SETB SCL
    CLR C
    JNB SDA,INL11
    CPL C
    INL11: RLC A
    DJNZ R2,INLP1
    CLR SCL
    RET
    STOP1: CLR SDA
    NOP
    NOP
    NOP
    nop
    SETB SCL
    NOP
    NOP
    NOP
    nop
    SETB SDA
    RET
    add40: mov r3,#040h
    ad4: inc dptr
    djnz r3,ad4
    ret
    end
  • Hi geo,
    Mean while I go through your code I guess you can try using the following code for you interface,its in assembly...
    http://www.keil.com/forum/docs/thread2328.asp
    Rgds
    Raj Shetgar
  • hi i have no problem writing in eeprom. the only thing is that after the data i wish to save i get some trash too, wich i don't understand.
  • Ok,
    This happens for every byte written or only at the end of some lengthy string written into the EEPROM.
    Rgds
    Raj Shetgar
  • IT HAPPENS IMIDIATLY AFTER INPUT STRING IS OVER. THE INPUT STRING IS WITTEN CORECTLY IN THE EEPROM.
