Hello. Once you have downloaded a .hex file onto a MSC1210 board, how do you run it? I have downloaded several programs which should maybe, make and LED on the board flash, yet nothng happens. How do you make a program run once downloaded? Also, if the board is connected via serial cable to a PC, do you get the board to send data back, and how do you then read the DATA on the PC. Does anyone have any owrking programs that do this? Thanks.
Weren't there any example Projects with your MSC1210 board? Have you read the uVision "Getting Started" guide, and worked through the example projects there?
