Hi I have connect an ADC0804 to an AT89c52 to port P1 and the RD,WR, INT to P2. and the output is display on digtial trainner but If I increase the IN voltage to the ADC the display is not changing. The following is the code i am using Keil can any tell what is the problem #include<reg51.h> xdata unsigned char var _at_ 0x9000; void display(); void adc(); main() { P1=0xFF; while(1) { adc(); } } void adc() { P2=0x00; P2=0x40; if(P2==0x80) { P2=0x00; var=P1; display(); P2=0x20; } } void display() { #pragma asm push dph push dpl push acc push b mov dptr,#9000h movx a,@dptr mov 60h,a lcall 019bh pop b pop acc pop dpl pop dph #pragma endasm }
