I always get an error 129 (missing ';' before 'void') when I compile in this part: func void iicstart (void) { sda = 1; scl = 1; del4us () sda = 0; del4us () scl = 0; del4us () } what is wrong?
Is this supposed to be 'C'? If so, what is func?
Should there be a ; after del4us ()??? Jon
"func" is the problem. "Missing ; before <token>" is one of those compiler error messages that you wish actually says what it means. Normally, I see this error when there is an undefined type for a return value of a function. ForgotToInclude f() - Missing ; before f.
"'Missing ; before <token>' is one of those compiler error messages that you wish actually says what it means." What it means is that the compiler expects nothing before <token>; therefore, if it finds something before <token>, it assumes that there should've been a ';' after the "something" !!
"Should there be a ; after del4us ()???" Surely, there should be a ';' after each del4us() ?!
Maybe del4us() is a macro that inserts its own semicolons? #define del4us() _nop_;_nop_;_nop_;_nop_; (Not a style I would recommend. I write macros that look like functions assuming I'll put a semicolon after them at the point of use.)
On second look, it appears you have debugger functions confused with C functions. When writing your C program, you must use ANSI C rules. And, func is not a part of that rule set. If your function is intended to be used in your program, you should modify it as follows:
void iicstart (void) { sda = 1; scl = 1; del4us (); sda = 0; del4us (); scl = 0; del4us (); }
func void iicstart (void) { sda = 1; scl = 1; del4us (); sda = 0; del4us (); scl = 0; del4us (); }
