CRC problem
I have used this C code posted by others in the forum. But i found that i can only do CRC for 7 bytes. Is it the problem of only 16 elements in the feedback array? or why?
 *     NAME: Crc8()
 *  PURPOSE: Generate 8-bit CRC.
 *  SYNOPSIS:   unsigned char Crc8(unsigned char b, unsigned char initCrc);
 *  INTERFACE PARAMETERS:
 *      Name                 FG-IO  Description
 *      b                    F  I   Data byte to CRC (MSBit first).
 *      initCrc              F  I   Initial CRC or CRC accumulator for
 *                                  continuation.
 *      <return value>           O  CRC.
 *  DESCRIPTION:
 *      The function returns the 8-bit CRC after including "b" with the
 *      initial CRC "initCRC".
static const UCHAR code feedback[16] =
        0x00, 0x07, 0x0E, 0x09, 0x1C, 0x1B, 0x12, 0x15,
        0x38, 0x3F, 0x36, 0x31, 0x24, 0x23, 0x2A, 0x2D
UCHAR CRC8(UCHAR b, UCHAR CRC)
    CRC = (CRC << 4) ^ feedback[((CRC) ^ b) >> 4];
    CRC = (CRC << 4) ^ feedback[((CRC >> 4) ^ b) & 0x0F];
    return (CRC);
  • By the way, i hope to do CRC for 256 byte data and i just input 0xFF for the initial CRC. Is there anything wrong?
  • "But i found that i can only do CRC for 7 bytes."
    What exactly is the problem? Examples of failure would be the things to post.
    "Is it the problem of only 16 elements in the feedback array?"
    Feedback tables have 2**n elements, where 'n' is the number of bits being processed in parallel. In this case the CRC is calculating 4 bits at a time, 2**4 = 16, so the feedback table should have 16 elements. No problem.
  • "By the way, i hope to do CRC for 256 byte data and i just input 0xFF for the initial CRC. Is there anything wrong?
    That is too much data to cover with only an 8-bit CRC. Generally speaking, an n-bit CRC's error detection properties degrade after 2**(n-1)-1 data bits. Thus, an 8-bit CRC should be avoided for data blocks over 15 bytes in length. For 256 byte data, you really should be using a 16-bit CRC.
