RTC keil C programming
currently i m using MSM62X42B RTC CHIP to interface with 8052 up.
below is my </initial> programming to stop the clock and write in the 12 hr bit.
The moment I execute pinWR = 0; the programme drop stop running. And I assign another pin rather then P3^6 and it does the same. I was wondering what could be the issue?
#define THSR XBYTE[0X6F00] // the 'F' of J1 is assign to A9-A11 of the RTC
sbit pinWR = P3^6; // this write is tie to WR of the RTC and ADC 0803
void main(void)
pinWR = 0;
lcdPutStr("TIME:");
THSR = 0x00; // test = 0
THSR = 0x01; // rest = 1 to stop clock
THSR = 0x01; // set 12 hr
THSR = 0x03; // set stop bit to stop count
THSR = 0x02; //start clock
THSR = 0x02; //ser 12 again
