Hi people, I would want to have a small favour done.In my applications I really don't require to worry abt using different memory types or specify models or handle data and program storage destinations. Here are the few basic blocks that I work with: 89c52 with no external mem 89c52 with no external mem but interfaced to 9 UARTS thru PAL logic and memory mapped I/O 80c320 with 32K ext RAM and the 28f001 as ROM 89c51 RD2 with no external mem Now for the problem... There r no straight guidelines while setting Target Options for the A51,BL51,C51 and I really get confused. The memory specifications also create questions. Is there no straight method dependant only on the memory model that will create a nicely compiled code. What currently happens is the pointers that I use give me various errors all related to memory!! I have deliberately not posted the errors I get because I wanna go thru the learning cycle.Of course if my problem's not solved that's the next thing I'll do! Actually most of the code I write has already been tested and verified using the old dunfield command line compiler. Please help make my compiling just as simple using uv2. Thanks anyway, Gautam
"I wanna go thru the learning cycle" Have you read the uVision Getting Started Guide, and worked through the example Projects?
As Andrew said, see the Getting Started manual. Play close attention to the multiple Targets Options. You can have a different Target and Option for each Device and each memory config. You can enable and disable selected source files for each Target configurations. You cannot 'option out' different modules but you can place these modules in individual source files and set the options for a source file. Bradford
Yes of course the user's guide has been read And even the sample programs have been compiled.What is missing is a brief description of the hardware or the board specifications that have been kept in mind while writing these sample programs.Yes in some cases it is mentioned that the the program is for some particular development board...but then does not go on further to describe the memory layout on those boards (e.g. external mem interface, etc.) Probably all that I have learnt till now is thru examples but haven't been able to build up on this particular aspect. Anyway now for a direct ques.. I have a UART mapped at 0xc800 and I access all its registers using an offset.c51 gives me an error abt invalid mem space.On the board decoding logic and a PAL generate this addr for the chip but obviously the compiler overlooks such possibilities. Will try to slip in code later. Thanks
My project happens to have memory-mapped hardware residing at 0xF000. I have no trouble accessing it. For the uVision target dialog, I told the tools that they had xdata ranging from 0x4000 to 0xA000. (I was saving 0xA000-0xEFFF for a software stack and memory pool; 0-0x3FFF is used for a different purpose.) So I've made the linker's job relatively complex. To access the registers of my device, I've got some macros to declare the registers that essentially boil down to: *(volatile U32 xdata*)(0xF000 + offset) Could you post the code that gives you the "invalid mem space" error? If you have no xdata at all in your project, perhaps you need to tell the toolchain about your UART at 0xc800 (and reserve the address range of the registers, just to be safe). Or perhaps you're not using an explicit memory type qualifer for your pointer? How exactly do you generate the address for your register access?
