New array declaration
Hi everyone
can someone tell me how to declare a array of 20 characteres. I wanto to use this array to fill with a string and then display it in a LCD. Also I wanto to use a pointer to read or write in this array
thanks
  • Store the string in code ROM:
    char code str[21] ="This can be display.";
    LcdDisp(str);
    while the argument of LcdDisp() should be a "unsigned char " pointer,like
    char *LcdDisp(char *StrSrc);
    Good days!
  • Sounds like you need to get a 'C' textbook!
    "Store the string in code ROM"
    That will give a fixed string that can't be changed at runtime.
    Is that what you actually wanted?
    Note that there is no need to specify the array size when it is initialised with a string at definition:
    char code str[] ="This can be display.";
  • If your want to read and write in an array,u can declare the array in idata or data RAM,if external RAM is valid,xdata could be used
    char idata/data/xdata str[21]="read and wirte here.";
    Note that,in C,a string ends with a '\0',if U want to store a 20-character string in a arrary,your will have to assign 21-character space for it.
  • "to store a 20-character string in a arrary,your will have to assign 21-character space for it."
    But, as I said earlier, there is no need to explicitly specify the length (eg 21) in the definition - the compiler will do it automatically.
    In fact, unless you have a specific reason to do so, it's usually best not to specify the size - then there's no risk of miscounting, or if someone changes the string without remembering to change the size...!
  • but, if the length of the string which you declared is twenty,you don't need to specify the length,but while it is less than 20, for example
    char idata str[]="hello";
    however,you need to store a 20-length string later on, does's it work?
    eg.
    strcpy(str,"this a 20-char sting");
  • "you need to store a 20-length string later on"
    that's why I said, "...unless you have a specific reason to do so..."
    In that case, yes - you would need to explicitly state the length as 21 in the definition.
    The 1st parameter to strcpy just tells it where to start copying to; see strncpy if you want to limit the maximum number of characters to copy!
