I try to use hardware i2c on XC161CJ with TimeKeeper M41T56. As examle, take source code from C161 manual, but there are some trouble. May be, some of fachmans have little succesfull example of hw i2c ?
"there are some trouble" What trouble?
Thanks, Andrew, for your answer. In two words, problem look so. As ground for my primitives, I use code from C161... User Manual. And in some cases it work good. But, when I compile it with another Code Optimization Level ( Keil ), the program do not set initial adress in timekeeper memory. I see as Keil work in different way, but, at my look, all is correct and I can't understand this dependencies ( now :)). I think, the reason is in my poor understanding of hardware i2c work. I solve this in real project with software i2c protocol, but in case with tight real time requirements it is not good. Certainly, this kind of bugs is difficult to discuss here. Thanks anyway, Good luck, Valery
"I think, the reason is in my poor understanding of hardware i2c work." If changing optimisation levels breaks your code, it could be your understanding of optimisation? Have you been sure to use the 'volatile' keyword where necessary? Are you relying upon 'C' software loops for timing? Did the C161 User Manual make any specific mention of optimisation? Or any other restrictions/limitations/warnings?
Thanks, Andy, for your advices. They force me to explore this question more accurate. I find out, that at max speed ( 40MHz CPU, all timings of external memory = 0 ), some delays between operation with i2c registers are critical. I don't like _nop_s at all, but in this case they are really needed. If you wish, I can prepare little project to demonstrate my exploring. My mail is ( divided to avoid spam-amateur ) larry_ @ aport2000 . ru Best wishes, Valery
