Hi, I'm trying to define a bit variable at a specific bit location. I tried the following without succes:
BSEG AT 02FH.7 MYBIT: DBIT 1
TEST_BIT SEGMENT BIT RSEG TEST_BIT MYBIT: DBIT 1
DSEG AT 02FH MYBIT8: DS 1 sbit MYBIT=MYBIT8^7;
I have never tried this, but it could be that BSEG needs a regular numeric address like this:
BSEG AT 07FH MYBIT: DBIT 1
Or I could assign the whole byte and then target the bit that I want (but then I have 7 unused bits): Not if you do
DSEG AT 02FH MYBITB8: DS 1 sbit MYBITF8=MYBITB8^0; ..... sbit MYBITFf=MYBITB8^7;
Graham,
Erik,
sbit MYBIT 0f8h;
BSEG AT 30h ; absolute bit segment @ 30h DEC_FLAG: DBIT 1 ; absolute bit INC_FLAG: DBIT 1
The syntax is indeed correct, but is there something more to do to avoid the link error? BSEG AT 30h ; absolute bit segment @ 30h yes, locating the BSEG withinthe bit addressable area. Erik
Erik, I was using the LX51 linker. It looks like I have to define the address once more in the user segments to get it linked :
?BI??TEST?1(0x2F)
