Pulling my hair out on this. C932 codes runs in my hardware using ICE. Burn a chip, checks OK, replace emulator with chip – Dead In The Water. Any ideas from our 932 Guru's? Thanks
ok with ICE, not ok with chip usually is one of these 1) faulty power on reset (the ICE does its own) 2) overrun becuse ICE has more memeory than chip 3) no power to uC (the ICE does its own) 4) oscillator not running Erik
just an hour ago I received some boards from a new contrat manufacturer - those from the former worked - that did not work. I stuck the emulator in and they worked. Problem: reset series diode turned wrong way. Erik
