I am using the C51 professional developers kit with µVision 2 (Version 7.09 for the Compiler) to develop for an Nordic nRF24E1 (256 Byte idata Memory) For debugging purposes i want to display the internal memory (View->Memory Window) but the memory window will not display anything. I can select the memroy #X banks but all i get is an empty window displaying only the white background. If i try to enter a memory location into the respective textbox all i get is a Beep and nothing happens. It actually worked the first time i used this options but has not since. Even deleting the *.opt files has achievede nothing. Is this a bug or am i doing something wrong? Regards Christian
