RTC
how can i set the real time clock (RTC) in 8052 by using c51
  • Uhm,
    The Clock address is at external data. meaning it is a xdata.
    You probably need to set up some kind of addressing using a Gal22V10 to put the clock at some external address.
    Once you do that, you do something like...
    //Clear Alarm Bit
    Data = XBYTE[CLOCK_ADDRESS + REGISTER_C_OFFSET];
    Once you get past that part, I have been reading about how you can set the segment. So you can access the Clock, without using Xbyte, but that is later on.
    HTH,
