SVCS and Sourcesafe's current project...
Hi
Is there a way to ensure that "Set Current Project" is selected before the next SVCS command is issued?
The reason I ask is that if I have two Keil projects open and I forget which project is "current" to sourcesafe and I issue a command, I may end up really screwing up an existing project file.
For example, project1 has a file called main.c and project 1 is current. If in project2 I also have a main.c file and I check it in, I have just messed up my project.
Any tricks to get around this other than remembering to hit the set current project EVERY time?
James
