Hi All, I need to make portable ANSI-C code, any advice how easier to hide "idata"? I use small memory model, and wouldn't change it. Regards, Vladimir
See my recommendation here: http://www.keil.com/forum/docs/thread31.asp
Write your code with something like the following typedefs and macros, and redefine them appropriately for each compiler you use:
typedef unsigned char U8; typedef unsigned short U16; typedef unsigned long U32; typedef struct { U8 byte[8]; } U64; typedef signed char S8; typedef signed short S16; typedef signed long S32; typedef struct { U8 byte[8]; } S64; typedef unsigned char Bool; /// fast, probably small data RAM #define FAST data /// large, probably slower, data RAM #define BULK xdata /// data beyond the normal range of data RAM #define FAR far // program store #define CODE code #define REENTRANT reentrant
Thank you for your answers! Best Regards, Vladimir
