segment selection
Hi all,
I'd like to know if it is possible to select a segment from another one. I explain:
usually you do this:
CODE_SEG segment CODE
rseg CODE_SEG
what I want to do is:
rseg ANOTHER_CODE_SEG
Thanks for answering, Gilles
  • Your request isn't exactly making much sense.
    The two statements in the pairs you show are actually independent commands. There's absolutely nothing forcing you to always use them in pairs. One defines a segment, the other tells the assembler that subsequent code/data are meant to go into the given segment.
