ST10 interupt handling problem
I'm using Timer T6 to generate a clock for a device and I want to keep a count of these clock pulses.
Also I want to use CC12 as positive edge interupt (P2.12). I have kept the priority of this interupt higher than that of the timer.
I have pasted the code to achieve this below.
My problem is that when I try to give interupt on P2.12, the CPU enters T6 interupt routine.
Please can anyone help me solve this problem.
Thanks and regards
Sonali
#include <stdio.h>
#include <reg167.h>
sbit ADC_CONV = P3^5;
sbit ADC_BUSY = P2^12;
unsigned int num = 0x00;
void timer6(void) interrupt 0x26
num++;
void adc976(void) interrupt 0x28
ADC_CONV = 0;
ADC_CONV = 1;
void main(void)
P2 = 0x0000;
DP2 = 0x0000;
P3 = 0xFFFF;
DP3 = 0xFFFF;
CC12IC = 0x46;
CCM3 = 0x0001;
T6 = 0x6768;
CAPREL = 0xFFC3;
T6CON = 0x8201;
T6IC = 0x44;
T6R = 1;
IEN = 1;
ADC_CONV = 0;
ADC_CONV = 1;
while(1)
