Hi, The compile error is: WARNING L15: MULTIPLE CALL TO SEGMENT SEGMENT: ?PR?_STRTONUM?PARSE CALLER1: ?PR?TC0?PERIPHERAL CALLER2: ?C_C51STARTUP The callers TC0 is an ISR using reg bank 2 and I don't know about the c51startup. The called function STRTONUM is using the directive of #pragma NOAREGS so can be called for any functions. The question is why I still got the multiple call error? Thanks for answering my question. By the way, C51 is V6.21, BL51 is V4.21 and LIB51 is V4.20. chao.
Supplement: I know that C51START is the STARTUP.A51. Function main() also calls STRTONUM function. As the result I have two different functions using different reg banks to call STRTONUM. But still, why would I get multiple call warning since the directive of NOAREGS is used on STRTONUM? Can this warning be ignored? chao.
Function main() also calls STRTONUM function. As the result I have two different functions using different reg banks to call STRTONUM. But still, why would I get multiple call warning since the directive of NOAREGS is used on STRTONUM? Can this warning be ignored? You are calling a function from main AND an interrrupt. 1) this is bad practice 2) if you insist on using this bad practice, you must also make the code reentranr. Erik
"why would I get multiple call warning" You get the multiple call warning because you have multiples calls - as you yourself have acknowledged. Simple as that! "the directive of NOAREGS is used on STRTONUM" That, together with the different Register Banks, should mean that your Registers are safe - but it does not guarantee that all your local variables are safe! Check your mapfile to see whether any parameters and/or locals are being allocated at fixed memory addresses. It is possible that your code is safe - the Linker just can't guarantee to do enough analysis to be sure of this, so it gives you this warning that it might not be safe. If you are absolutely certain that your code is safe, you can just ignore the warning - that's why it's just a warning. But having warnings as a normal part of your build is a maintenance nightmare...
OK, after I read some threads and I found out one thing: both interrupt and non-interrupt functions call the STRTONUM function. Under this circumstance, I should do something "reentrant" on STRTONUM since STRTONUM can be called "at the same time". Am I correct? By the way, it seems there was some one tried to response my question unfortunately I could not see the reply. Thanks anyway. chao.
erik, First, thank you for your help and thanks to Andy too. I agress with your points. Since it is a bad practice, is there any way to get around other than using reentrant? chao.
is there any way to get around other than using reentrant? Yep. I do this all the time. Here are the main points to consider.
Jon, Thanks, got your help. As I understand you gave me two ways to workaround, disable the interrupt and disable overlay. Here is my project structure: 1. Data is received from uart (interrupt is used). 2. Main() is to analyze the received data and display the result on a screen (LCM). The analyzed data will be shown in different pages, selected by a user. 3. Another ISR (timer 0 to detect a keypad) is also to display the analyzed data on the screen for quickly responding to a user's input. In short, both main and the ISR functions are doing the same thing. The only difference is that ISR can quickly response to a user, simple as that. So my program would not work if I disable the interrupt. On the other hand, if I disable overlay it would take lots of xdata space due to the display subroutines. Do you have any suggestion? chao.
Presumably, this STRTONUM function is just doing some sort of formatting for the display? Why not just keep the formatted result in a buffer, so that both main and the interrupt can access the buffer when they need to display it? This also has the advantage of relieving the ISR of the task of doing the formatting - which is generally a Good Thing.
Writing to an LCD is a very slow (relatively) operation, and not the sort of thing you should be doing inside an interrupt service. Your ISR would be better off setting a flag to note that the LCD requires updating, and regularly check this flag in your non-interrupt code.
Could you not just set a flag in the ISR indicating that main() should call the function? This is the usual sort of technique to avoid these kind of problems. Stefan
In short, both main and the ISR functions are doing the same thing. The only difference is that ISR can quickly response to a user, simple as that. OK. So what happens if main is in the middle of displaying the data and the interrupt occurs to display the data? So my program would not work if I disable the interrupt. Why? I only suggest disabling the interrupt when the main program calls the function. I do not suggest that you completely and forever disable the interrupt. if I disable overlay it would take lots of xdata space due to the display subroutines Really? Have you tried this? Overlaying, in this case, prevents the display routine from corrupting variables in other functions (that were overlaid with the display function). Do you have any suggestion? Yes. I already gave you THE best suggestion. But, since you don't like it, here are several software kludges that you can try: 1. Make 2 copies of the display function. One to be called from the main program and the other to be called from the interrupt. 2. Make the display function reentrant and define a reentrant stack. 3. Only call the display routine from the main function if a flag is set. Then, in the main program and in the interrupt set this flag whenever you want to display the information. 4. In the main program, rather than call the display function, invoke the interrupt by manually setting the interrupt request bit in software. 5. Connect another inexpensive 8051 to your hardware design to run the display function. Trigger it by connecting an output pin from the primary 8051 to the external interrupt input. Then, in your main program and interrupt you can simply toggle the output pin. Maybe one of these is helpful. Jon
#pragma disable seems to generate code thus:
; prologue SETB C JBC EA,?C0069 CLR C ?C0069: PUSH PSW ; epilogue POP PSW MOV EA,C RET
; prologue PUSH IE CLR EA ; epilogue POP IE RET
So what's going to go wrong with this method? This works!
#pragma disable void init_serial_isr (void) { ES = 1; /* enable serial interrupts */ }
; prologue PUSH IE CLR EA SETB ES ; epilogue POP IE RET
That's the sort of thing I had in mind in the last sentence (the C routine making other changes to IE). The compiler has to play it safe for the general case. In my case, I have the advantage of some extra information about what the routines are doing, so preserving IE modification isn't a problem. I suddenly panicked that I had overlooked some subtle 8051-ism about disabling interrupts and just hadn't noticed the error in the lab yet.
Thanks for all of you who try to help me. I have three layers of buffer for data. The first layer is for UART raw data. The second layer is a copy of the raw data for the main() to analyze and not to "disturb" the work of UART. The third layer is for the result, the analyzed data for the displaying purpose. So Neil's concern has been taking care of, unless I misunderstand his point. A LCM is slow relatively. Got Collett's point. I will keep that in mind. The reason I need to do display things in an ISR is to quickly display the page an user is selected. If I only use a flag to signal the main() then display, it will be "slow" to react to an user's request. This approach was my first attempt. The good thing about this approach is save, simple and won't have problem like Jon mentioned, "what happens if main is in the middle of displaying the data and the interrupt occurs to display the data" which I realized last night. Jon, it was not I didn't take your solution. Maybe I tried to be "perfect" (in my own way) on this project since this was the first project I had and not fully understood both my project and the compiler. You know, it is the "first time" thing. Please keep posting your new ideas. I really need that. Thank you very much. chao.
