hi I need simple c codes for atmel 89c51 to start experimenting with. I've not idea what library files to use for this particular chip. please help. Thanx
"I need simple c codes..." Look in the examples directory installed with your compiler. "I've not idea what library files to use..." uVision selects the proper files per your device selection.
Your post here http://www.8052.com/forum/read.phtml?id=52600 suggests that you are not even using Keil Software products, or are you?
hi I have access to most of the popular 8051 softwares (including keil).I have all of them in my institute's lab. regards
