Q: Compiler generates wrong Assembler Code
I am involved within the development of some control hardware using the Infeneon XC161 processor with a "self made" evaluation board.
I think something is wrong with the compiler.
First I thought that there is a bug on the board, but most program parts are running.
Measurments on the board end up in the result that everything works fine.
I used the internal debuger to check out what asm code really has been generated.
I was upset! Some Variables are lost after a function reentry. My code works fine with constants, but if I put some evalation expressions between the lines everything goes wrong.
Here is the Code example:
This short code should write integer numbers thoug the serial port. "putchar( uint )" works!
void NumToHex(unsigned int Handle)
const unsigned char numbers[16] = {'0', '1', '2', '3', '4', '5', '6', '7', '8', '9', 'a', 'b', 'c', 'd', 'e', 'f'};
//write the number into RS232
putchar('0');
putchar('x');
putchar( (unsigned char) numbers[ ((Handle & 0xf000) >> 12) ] );
putchar( (unsigned char) numbers[ ((Handle & 0x0f00) >> 8) ] );
putchar( (unsigned char) numbers[ ((Handle & 0x00f0) >> 4) ] );
putchar( (unsigned char) numbers[ (Handle & 0x000f) ] );
//and goto next line
putchar(10);
putchar(13);
this code always returns "0x ". But there should be something like "0x0a25".
If I try
putchar( (unsigned char) numbers[0] );
putchar( (unsigned char) numbers[13] );
putchar( (unsigned char) numbers[2] );
putchar( (unsigned char) numbers[1] );
I checked the range of my shifting-results.
All Numbers stay between 0 and 15.
PLEASE HELP ME. I nearly go mad with this.
Is there anything wrong with the compiler?
Have I forgotten a bracket?
Could there be a problem with my memory-configuration?
thanks for your answers
Jacek Wisniowski
  • Does the following code work?
    putchar(numbers[(Handle>>12) & 0x0f]);
    putchar(numbers[(Handle>>8)  & 0x0f]);
    putchar(numbers[(Handle>>4)  & 0x0f]);
    putchar(numbers[Handle       & 0x0f]);
    Jon
  • Hi Jon,
    The following line is mostly simple, but
    it's not working on my system.
    If I Try
    unsigned int dummy;
    dummy = 5;
    putchar(numbers[dummy]);
    it's working.
    There is a problem with math-expressions.
    dummy = handle & 0x0f
    isn't working, too.
    It's like voodoo. I think the expression is lost inside the generated assembler-block.
    But my debugger say's it's all right.
  • I just tried your example and it works just fine (whether I use your original or my suggested change).
    The code generated is as follows:
                 ; FUNCTION NumToHex (BEGIN  RMASK = @0x7FFF)
                                               ; SOURCE LINE # 6
    0000 ECFD          PUSH      R13
    0002 F0D8          MOV       R13,R8
    ;---- Variable 'Handle' assigned to Register 'R13' ----
    ;putchar( (unsigned char) numbers[ ((Handle & 0xf000) >> 12) ] );
    002A F04D          MOV       R4,R13
    002C 66F400F0      AND       R4,#0F000H
    0030 7CC4          SHR       R4,#0CH
    0032 F010          MOV       R1,R0
    0034 0014          ADD       R1,R4
    0036 A981          MOVB      RL4,[R1]
    0038 C088          MOVBZ     R8,RL4
    003A CA000000 E    CALLA     cc_UC,putchar
    ;putchar( (unsigned char) numbers[ ((Handle & 0x0f00) >> 8) ] );
    003E F04D          MOV       R4,R13
    0040 66F4000F      AND       R4,#0F00H
    0044 7C84          SHR       R4,#08H
    0046 F010          MOV       R1,R0
    0048 0014          ADD       R1,R4
    004A A981          MOVB      RL4,[R1]
    004C C088          MOVBZ     R8,RL4
    004E CA000000 E    CALLA     cc_UC,putchar
    ;putchar( (unsigned char) numbers[ ((Handle & 0x00f0) >> 4) ] );
    0052 F04D          MOV       R4,R13
    0054 66F4F000      AND       R4,#0F0H
    0058 7C44          SHR       R4,#04H
    005A F010          MOV       R1,R0
    005C 0014          ADD       R1,R4
    005E A981          MOVB      RL4,[R1]
    0060 C088          MOVBZ     R8,RL4
    0062 CA000000 E    CALLA     cc_UC,putchar
    ;putchar( (unsigned char) numbers[ (Handle & 0x000f) ] );
    0066 F04D          MOV       R4,R13
    0068 66F40F00      AND       R4,#0FH
    006C F010          MOV       R1,R0
    006E 0014          ADD       R1,R4
    0070 A981          MOVB      RL4,[R1]
    0072 C088          MOVBZ     R8,RL4
    0074 CA000000 E    CALLA     cc_UC,putchar
    This code looks correct to me (R0 is the user stack pointer and numbers is located on the user stack) and furthemore it runs correctly.
    Maybe there is another problem? How are you testing the code? Have you used the correct startup code for the XC devices? Where is the user stack located? Is that memory area valid? Do you get any compiler warnings or linker warnings?
    Can you show the assembler code generated for your C function? That is probably the first place to start looking if you think you've found a compiler bug.
    Jon
  • Maybe there is another problem? How are you testing the code?
    I use de Debugger and upload to my hardware-device.
    I think so. Most components work, just this one is not working.
    Yes. There was a problem with the user stack in a previous code-version. A bigger User stck solved problems with procedure calls. But a bigger Stack Size results in "out of memory" behaviour.
    No, no errors and warnings.
    I think that anything is different between the debugger settings and my device settings. But I dont't know where to look for.
    I've had problems with calling procedures. we made some changes in the memory setup and after that the calls worked. I will try to call the HexNum()-code in main(). If this is working it might be the startup-code (stack).
    Do you know any problems with startup-code, memory setup and function-calls?
    My assembler code looks similar to yours.
    What errors can result from wrong startup-code (I took the default-startup-code for XC161)? I work with the "medium" Memory modell.
    I can show you the assembler code in my next posting after I am at work again, tomorrow.
    Jacek
  • My assembler code looks similar to yours.
    Well, mine works so the generated code isn't the problem.
    Just about any kind of error you could imagine. For example, the chip selects are configured in the startup code. If this is not configured correctly, your program would appear to have no RAM or ROM memory.
    Your problem really sounds like a configuration issue. Have you checked to see that the startup code matches your hardware configuration?
    Jon
  • Hi Jon, this is my Assembler-Code:
    545: void NumToHex(unsigned int Handle)
    00010246 ECFD      PUSH     R13
    00010248 F0D8      MOV      R13,R8
    0001024A 06F0F0FF  ADD      R0,#0xFFF0
       546: {
       548:         const unsigned char numbers[16] = {'0', '1', '2', '3', '4', '5', '6', '7', '8', '9', 'a', 'b', 'c', 'd', 'e', 'f'};
    0001024E F060      MOV      R6,R0
    00010250 E6F40040  MOV      R4,#0x4000
    00010254 E6F71000  MOV      R7,#0x0010
    00010258 CA00E609  CALLA+   CC_UC,?C_BCPYNN(0x109E6)
       550:         putchar('0');
    0001025C E6F83000  MOV      R8,#0x0030
    00010260 BBDF      CALLR    putchar(0x10220)
       551:         putchar('x');
    00010262 E6F87800  MOV      R8,#0x0078
    00010266 BBDC      CALLR    putchar(0x10220)
       563:         putchar(numbers[(Handle>>12) & 0x0f]);
    00010268 F04D      MOV      R4,R13
    0001026A 7CC4      SHR      R4,#0x0C
    0001026C 66F40F00  AND      R4,#0x000F
    00010270 F010      MOV      R1,R0
    00010272 0014      ADD      R1,R4
    00010274 A981      MOVB     RL4,[R1]
    00010276 C088      MOVBZ    R8,RL4
    00010278 BBD3      CALLR    putchar(0x10220)
       564:         putchar(numbers[(Handle>>8)  & 0x0f]);
    0001027A F04D      MOV      R4,R13
    0001027C 7C84      SHR      R4,#0x08
    0001027E 66F40F00  AND      R4,#0x000F
    00010282 F010      MOV      R1,R0
    00010284 0014      ADD      R1,R4
    00010286 A981      MOVB     RL4,[R1]
    00010288 C088      MOVBZ    R8,RL4
    0001028A BBCA      CALLR    putchar(0x10220)
       565:         putchar(numbers[(Handle>>4)  & 0x0f]);
    0001028C F04D      MOV      R4,R13
    0001028E 7C44      SHR      R4,#0x04
    00010290 66F40F00  AND      R4,#0x000F
    00010294 F010      MOV      R1,R0
    00010296 0014      ADD      R1,R4
    00010298 A981      MOVB     RL4,[R1]
    0001029A C088      MOVBZ    R8,RL4
    0001029C BBC1      CALLR    putchar(0x10220)
       566:         putchar(numbers[Handle       & 0x0f]);
       567:
       568:         //and goto next line
    0001029E F04D      MOV      R4,R13
    000102A0 66F40F00  AND      R4,#0x000F
    000102A4 F010      MOV      R1,R0
    000102A6 0014      ADD      R1,R4
    000102A8 A981      MOVB     RL4,[R1]
    000102AA C088      MOVBZ    R8,RL4
    000102AC BBB9      CALLR    putchar(0x10220)
       569:         putchar(10);
    000102AE E0A8      MOV      R8,#0x0A
    000102B0 BBB7      CALLR    putchar(0x10220)
       570:         putchar(13);
    000102B2 E0D8      MOV      R8,#0x0D
    000102B4 BBB5      CALLR    putchar(0x10220)
       571: }
    It's not woking with my device.
    I will check stack and memory settings.
    Thank you for your help.
    Jacek
