I want to make a new project with Device type Philips P5CD032 (SmartMX). But I can't find P5CD032 in the Device type list. But in example, SmartMX\stanford, I can see the target P5CD032 on Project Options. How can I make the new project with P5CD032?
Don't know what your project is all about, but if you don't find the device, you have to create one your own. The following link explains you how to do this: http://www.keil.com/support/docs/1421.htm --Geert
Maybe some additional info: if you created a new device, it will automatically be added to the file 'uv2.cdb', which is the device database used by uVision2. You can find this file in the UV2 directory of your Keil installation. Open the file in an editor and search for your new device. You will see some cryptic information, but you will be able to read some of the settings (eg. CLOCK). Beware: it is not the intention to change this file with an editor!!! --Geert
Have you got the latest version of uVision?
