Why uVision2 does not simulate 8952. This compiler does not understand 8952 registers(example TR2, T2MOD, T2CON...) Nguyen The Son
Which 8952? The device database in uVision lists some Atmel as well as Philips parts with that number. The Atmel device seems to have a T2 peripheral simulated in uVision, at least to a casual glance. The compiler "understands" registers defined in a header file. You could always write your own, but many, many parts have headers already written and supplied by Keil. For example, there's a c:\keil\C51\INC\Atmel\AT89X52.H on my hard drive that has definitions for timer 2 (T2MOD, TR2, T2CON, etc.)
I think compiler already supplies reg52.h which can be used or otherwise use can just declare those SFR's . Its rather easy. Nitin
What is Euler Integral formula ? What is PID algorithm do you often use ? Best Regards, Nguyen The Son.
"What is Euler Integral formula ? What is PID algorithm do you often use ?" That'll be two unrelated new questions, then? Normally, you should start a new thread for each new question. However, neither of these questions has anything specifically to do with the Keil software tools - so, strictly, they're off-topic here. http://www.keil.com/forum/ I suggest that you do some research in your library, and with your favourite internet search engine. http://www.8052.com/forum/read.phtml?id=60775
