Creating a not-so-portable Delay library
I'm rather new to Keil C and just getting geared up to use it on my next project. ATM, I'm overwhelmed with the number of options and extensions that are available. I intend to write a C "library" that consists of 3 functions:
Delay()
DelayMS()
DelayUS()
These will be used as follows (examples):
Delay(2);        // creates a 2 second delay
DelayMS(500);    // creates 500ms delay
DelayUS(10);     // creates a 10us delay
I realize a timer could be used, but I'd like to have a few generic approximated delay functions available that do not occupy a timer module.
Is this even possible? I realize exact accuracy would not be possible. But a 502ms delay (or even as much as 10ms off) would be sufficient for my needs.
I'd guess I will need to write a delay loop in assembly and call it from C correct? And of course if a controller or clock got changed, i'd have to update my library..
John
  • Is this even possible?
    Yep. I do this kind of thing all the time.
    Why? There's no need to do that. You can do everything in C.
    You should create a separate C file for each function. For example:
    DELAY.C
    void Delay(void)
    /* insert code here */
    DELAY_MS.C
    #include <intrins.h>
    void DelayMS(unsigned char ms)
    unsigned long us = 1000*ms;
    while (us--)
      _nop_();
    DELAY_US.C
    void DelayUS(unsigned char us)
    while (us--)
      _nop_();
    Then, compile the files into .OBJ files. Then, use LIB51 to build a library. Finally (or maybe as you go), create a header file for the routines in the library. You may even include the library header file in the library source files as a double-check of function prototypes.
    You can, of course, create a uVision2 project to create a library.
    Obviously, these routines must be tuned.
    Jon
  • Yeah, I guess that would work just as well since no matter what you would need to "hand tweak" it anyway.
    Thanks for the tip!
    John
  • Why? There's no need to do that. You can do everything in C.
    That would make the delay dependent on:
    1) optimiser settings
    2) compiler version
    3) memory model
    so, to make it 'future safe' you must do it in assembler.
    PS It's dead easy
  • I am a newbie to Keil and I am using 8051 based USB 2.0 device. Both IFCLK and CLKOUT are at 48Mhz.
    I want to implement a function that would introduce 1 microsecond delay.
    Can you please help?
  • I agree with Erik: even if you write it in 'C', you're going to have to look at the generated assembler to see how many NOPs to add anyhow - so why not just do it straight in assembler in the first place?!
    And, of course, with assembler WYSIWYG - you are not at the mercy of the compiler's and/or optimiser's whims!
    What I have done is to write two functions:
    void Wait_1us( U8 n );  // Wait n+2 us
    void Wait_10us( U8 n ); // Wait 10n us
    For Wait_1us, I couldn't get over the 2us "overhead" in the call, so I created a macro WAIT_1US to handle the offset:
    #define WAIT_1US( us ) Wait_1us( us-2 )
    With Wait_10us, there was plenty of slack to take up to allow for the overhead.
  • Just for the sake of variety:
    If you have a timer running, you can read the timer value to implement your delay loop. You don't have to set a timer value and code up an interrupt handler, or interfere with the existing use of the timer for another purpose. It's sufficient to read the timer, calculate your desired end value, and just spin while polling the timer value until the timer gets to the end.
    As with anything time-related, this is easiest to code if you know your delay time will be less than half the maximum range of the timer value.
  • Some time ago Jon Ward posted this macro here: http://www.keil.com/forum/docs/thread1940.asp
    You may find it useful for short delays:
    #define NOPS(x)	\
    	(((x) & 1) ? _nop_() : 0),\
    	(((x) & 2) ? _nop_(),_nop_() : 0),\
    	(((x) & 4) ? _nop_(),_nop_(),_nop_(),_nop_() : 0),\
    	(((x) & 8) ? _nop_(),_nop_(),_nop_(),_nop_(),_nop_(),_nop_(),_nop_(),_nop_() : 0)
    What would be really useful is to be able to make the source code sensitive to the target options such as crystal speed (by means of a predefined macro constant) so that the same code could be used again and again for different projects.
    Of course, the compiler would also have to know how many clock cycles are required for a NOP - since the simulator needs to know this for timeing, presumably this information is available somewhere within Keil.
  • Oh dear! My post did not do that on preview!
  • Hi,
    2 questions here:
    (1) I tried the nop way as you suggested, how come the delay I get does not change much if I give 'us' 2 very different values?
    (2) I use the following code:
    void delay_us() {
        SysTick->VAL = 9000;
        while(SysTick->VAL != 0) {}
    and delay also does not change much for VAL 2000 and 9000.
    Does it have sth to do with code optimization? I am using IDE's default setting.
